ecdez
Posts: 575 Joined: Wed Apr 24, 2002 1:01 am
Post
by ecdez » Fri Dec 15, 2006 8:27 am
I'm finally putting my engine back together and can't remember if the Type 3's use the same bottom cooling tin like the type 1 (bottom row in picture below). I can convince myself either way, but would rather do it right. None of the manuals show the tin for the bottom, only the top; but the top tin has hole where it looks like bottom tin should mount.
Any input?
sideshow
Posts: 3428 Joined: Mon Oct 27, 2003 11:00 am
Post
by sideshow » Fri Dec 15, 2006 7:51 pm
Just like a type-1, except it has an extra “rib” as the pancake is wider than upright.
Air_Cooled_Nut
Posts: 313 Joined: Thu Apr 05, 2001 1:01 am
Post
by Air_Cooled_Nut » Sat Dec 16, 2006 6:26 pm
Did you remember to install the cooling tin that is between & below the cylinders?
'72 VW Squareback w/Berg 5-speed and ragtop
'76 VW Riviera Bus
'95 VW Jetta, Peloquin'd, CHE tranny, nicely modded
'81 Honda Goldwing, naked
'06 Ducati Sport Classic 1000 (monoposto)
ecdez
Post
by ecdez » Sun Dec 17, 2006 2:29 pm
I found the diagram and the tin I had misplaced late Friday night. Thanks for the responses.
Air_Cooled_Nut wrote: Did you remember to install the cooling tin that is between & below the cylinders?
I never removed that tin. I was just changing my push rod tube seals. Thanks for the reminder though.
