==Zero Rust????==
Posted: Tue Jan 09, 2007 4:44 pm
by MNAirHead
Anyone ever use Zero Rust.. I have a gallon and wanted to ensure i"m not making a mistake using it on the underside of our car.
Timmy
Posted: Thu Feb 01, 2007 8:30 pm
by takotruckin
i've used it a few times. once to seal my trailer before putting real paint on it, and i sprayed my wheels with it. its cheap, it stays on, no real complaints about it.
Posted: Tue Mar 20, 2007 4:49 am
by Xyclone
zero rust is awesome! As long as the surface your putting it on has enough bite, aka use some high grit samd paper on it or use it on really rusty metal. Ive used it on a few pans and one of which sat out in the weather for 2 years with standing water in it :shock: The zero rust only started rusting where I had to re-wirebrush but forgot to sand before painting it :oops: Its good stuff, but if your ordering more, order it straight from the manufacturer, JCwhiteney has priced it WAY up over the years......
Posted: Tue Mar 20, 2007 9:05 am
by MNAirHead
Did you ever try acid etching before zero rust?
Posted: Wed Mar 28, 2007 1:13 pm
by takotruckin
i used really rusty metal
wow, jcw price is double what i payed from our paint supplier :shock:
Posted: Wed Mar 28, 2007 3:04 pm
by MNAirHead
I just ordered some from Autobody.com... very good service.. had to find someone who had tan for our Cheowth frame.
Where do you buy yours (if it's not JCW)
T
Posted: Mon Apr 09, 2007 3:58 pm
by takotruckin
i buy mine from our Dupont supplier, they deliver to us every day. (we have a body shop).
Posted: Mon Apr 09, 2007 4:01 pm
by MNAirHead
Follow up question..
If you're dupont rep will supply it.. have you painted over it?
Posted: Mon Apr 09, 2007 4:15 pm
by takotruckin
yes, on my trailer, it was REAL rusty, i knocked the heavy stuff off, then sprayed it it with zero rust, let it dry like a week, scuffed it, then shot the whole thing with Imron, worked great. i screwed up somewhere and it took like 5 days to totally dry, but its rock hard now.
Posted: Tue Apr 10, 2007 1:40 am
by MNAirHead
Great.. thanks a ton...
I'm doing our rail in the tan color.. will be doing desert cammo on the shroud.. will let youknow if it melts plastic.
Tim
Posted: Wed Apr 25, 2007 2:48 am
by slowtwitch
You can also get Zero Rust thru Amazon.com. Good stuff :D
pete
Posted: Sun Apr 29, 2007 4:58 pm
by takotruckin
painted my paddle wheels this weekend. found out that if you thin the paint more, it will lay down real smooth. here is the freshly painted wheel(still wet, thats why its so shiny) compared to my beaten hard wheel that i painted over a year ago
