top hung pedals/ and other project pics
Hot Wheels
anybody done a set of circle track style top hung pedals in a buggy? got some pics? Im stuck on the tub buggy, neal floor mounts are just not cutting it in the limited space available with my size 12 stompers. Really bad foot angle, makes my ankles sore just testing it. If i can reverse the pedals and hang them it would really help. Master cylenders cant go out the front though as the gas tank is in front of the firewall. I hung the neals upside down and backwards to get a feel for it and maybe with remote reseviors it could work with the right pedal setup.
Ill post up pics of the mock up here in a bit.
http://s133.photobucket.com/albums/q70/ ... e%20Buggy/
Link to all the recent buggy pics.
Hot Wheels
Another project ive been working on is running a "sprint style bar from the rear shock mount out to the side bars. I roughed this one in the other nite but im not really diggin it. I want to tie the shock mount into another structure and give a little more side protection at the same time if possible. Probably goint to try a longer and a shorter version as well as the stronger straight version before i make up my mind. Then I need to get started on the rear cage before I finish out the body work.
- Leatherneck
Hot Wheels
Decision made. By tearing apart the CNC pedals and removing the pivot shaft I could hang the bracket upside down and stick the cylenders out the front under the tank. Got the height and angle I wanted. The only down side is the fill will be really a bear to get to under the tank and the hood. I think im going to drill holes in the caps and make a fill tube setup to a remote location. I can take the drivers wheel off to replace a cyl but most of the time you just need to add fluid.
Hope to get the perminant mounts made tonight. Really made the difference for my 6'2" frame and size 12s down on the pedals. This thing may be comfortable to drive yet! I may go to a fuel cell as well so it would allow me some more leeway up front with the pedal equipment.
- Leatherneck
Hot Wheels
Pics from the weekend
Added the side bars to the tree bars from the shock mount to add strength to both as well as a cup style mount to the top of the shock so it is double shear and will help keep the shock away from the body if anything ever did go wrong. Wrapping up lots of little issues that have been bothering me about the project. Ended up using the subaru brat rear seats with the grab handles for the kids. Progress at last.
- Leatherneck
- fusername
jyeah, on my rail i needed to address the whole room for feet issue, so now im cutting and shortening some stock VW pedals, and taking about an inch of brakes and gass. so much nicer for my poor lil 13s.
silly giants, beetles are for ladies!
Hot Wheels
allsierra123
