Need Lots of Help
nukeworker
Need Lots of Help
Post by nukeworker »
I bought the Watson's Streetworks kit. My Baja is a 66 body on a 70 pan. I can't figure out two things and hope someone can help. Don't know how to connect the turn signal wires with the kit. If someone has used this kit, maybe you can help. The kit claims it has the relays with it. Their tech support isn't great. The next issue is the wiper motor. The 66 wiring diagram just shows wires running to the motor. it doesn't show to where. The motor has 4 tabs labeled: 53a, 31b, 53, and 53b. Then there's a screw with a tab that I believe to be the ground. Any and all help would be VERY appreciated. By the way, the turn sig has a gr/blk, blk/wh, br/wh, a br with a piggy backed br, and a blk/wh with gr rings piggy backed with a blue.
Speedy Jim
Post by Speedy Jim »
Turn Signals first:
That switch will work just fine.
It only uses 3 of the wires:
Blk/Wh/Grn (common)
Blk/Wh (Left signals)
Blk/Grn (Right signals)
The circuit connections to the flasher look like:
http://www.nls.net/mp/volks/schem/flash3.gif
If you use a 3-terminal flasher instead, connect the dash light to 49a.
The Brw and the Brw/Wh wires are used for the headlight dimmer relay.
Wipers:
That sounds like a non-'66 wiper. It must be a 12V 2-speed model.
The wiring (simplified) looks like:
http://www.nls.net/mp/volks/schem/wiper2.gif
You must use the VW dash-mounted wiper switch for it to work
correctly and Park.
There is more miscellaneous wiring info on this page of my web site:
http://www.nls.net/mp/volks/htm/elec.htm
Feel free to e-mail me.
Speedy Jim
MNAirHead
Post by MNAirHead »
Welcome to STF NukeWorker..
Please check your PM for a note.
nukeworker
Thanks guys, I really appreciate your help. One thing I forgot to mention is that I also bought one of those variable switches for a 6 volt motor in a 12 volt system. So I guess that can't be used if I actually have a 12 volt wiper system. Or do you think it would still work cuz it would be nice to have variable speed?
MNAirHead
Post by MNAirHead »
Is your kit just a "Pot" (dial) with a resistor?
72bajaben
Post by 72bajaben »
you only have to use the stock wiper switch if you want the park feature to work. im using a 2 pole toggle switch. up for high, down for low.
nukeworker
No. It's that one from J.C. Whitney's with a transistor. I thought I had a 6 volt wiper system. Its supposed to enable you to use the 6 volt wipers in a 12 volt system. What is the park feature? Is that so you can stop them where ever they are? And why would you want to do that? Sorry, it's my first ACVW. Also, that two pole toggle sounds good.
MNAirHead
Post by MNAirHead »
Park returns the wipers to the resting spot.. not turning it off mid-wipe.
nukeworker
Here is my wiper switch. Don't know what year it is. Has different numbers than the wiring diagram you show. There's a 54d, 54, and a 31b. Also it pulls out one click and turns in either direction. Can some please explain the operation? How does the washer work? Image
Speedy Jim
That's a single speed switch. Like a '66.
(You could use it with a 2-spd wiper motor, running only one speed.)
Besides the terminals you can see, there is a "hidden" term #31,
which is grounded thru the shaft mount.
You can winkle it out from:
http://www.vintagebus.com/wiring/bug-65+66.jpg
Note that the switch term #'s don't match those on a 2-spd motor;
you'll have to transpose some numbers if you use it.
This simplified diagram is on my web site;
72bajaben
Post by 72bajaben »
if you want i can take some pics of how i have mine wired to a toggle.
Speedy Jim
I had done this for someone else a year ago so I had a drawing.
This is the 12V 2-spd motor with a Toggle switch (center Off type).
There is no Park feature with this.
(The switch "E" is only shown because it was part of
the original diagram.)
As 72bajaben notes, it's fairly simple to do.
nukeworker
Wow. Thanks guys. I think I will go with a toogle. It's an on/off road Baja so it doesn't have to be OEM.
72bajaben
Post by 72bajaben »
do you have the stock wires still coming off of your wiper motor?
nukeworker
No. I pulled the old wiring before I started. It was a rat's nest with all kinds of splices and unknown mods. Pretty much useless. I made the mistake of believing that the kit I bought would explain things a little better.
