Baja wiring - Painless Performance harness
Skidmark
Post by Skidmark »
I have started my wiring, and thought I would post a thread as I go through it. I am using a Universal Off Road harness (12 circuit and waterproof)) from Painless Performance. P/N 10140. The car has zero wires in it, so everything must be done as far as electrical. Here are some shots of the harness, and starting to pull it into the car.
I have almost all of the electrical parts I need with a few exceptions - radiator fans (don't have the radiator yet), horn, and reverse light. I will more than likely need more wire and connctors of different types, relays, and misc. other bits and pieces. I am estimating the wiring to take at least 40 hours of work. I want it to be a clean install, so I won't be cutting corners. A few weeknights and not every weekend means a long install...
MNAirHead
Post by MNAirHead »
Thanks Skid...
Posted Sticky....
Check your PM.
CopperBaja
Re: Baja wiring - Painless Performance harness
Post by CopperBaja »
Skidmark wrote:A few weeknights and not every weekend means a long install...
Skid,
I wish you luck on a quicker install than mine. 8)
Big Dave
Post by Big Dave »
Any updates? You didn't give up did you :D
I don't always show my signature. But when I do, it's in this area.
MNAirHead
Post by MNAirHead »
Interested..
Was it worth the extra money?
Skidmark
Post by Skidmark »
Sorry for the slow updates... I have been dreading this part of the build for a while now. The Painless harness does not include any gauge wiring, you need to do that yourself. I have about 6 hours into the gauge wiring. Probably because I am not very good electrically... :oops: I will post some pics up tomorrow of what I have done. We actually lit up the dash lights tonight using a battery (just to test them). I should get into the Painless loom soon.
MNAirHead
Post by MNAirHead »
No guage wiring? Is this with all Painless or is it just the painful one ordered?
Wow.. with this talent you could have wired your own loom.
Skidmark
Post by Skidmark »
All of the common grounds, lights, and +12 volt leads to all the gauges are not included. The signal wires, the main voltage lead to the gauges are included in the Painless harness. Keep in mind this is a universal harness, so all individual situations cannot be covered. Maybe you need more realistic expectations when it comes to buying electrical harnesses... :roll:
There are some circuits in the Painless harness that I will not be able to use as listed or designed in their harness. An example is the fact that I am not using a GM, Ford, or Mopar ignition switch. This harness is set up to hook into one of those three very easily. Since my application is unique, there will be some design challenges to get around...
MNAirHead
Post by MNAirHead »
Interesting...
If you need help posting pix.. I can host/post for you..
Would love to see an update.
CopperBaja
Yeah, me too. Although I'm not one to talk.
I'm at the same stage, but lack of time is killing my progress.... :(
Don't feel bad...even with the $325 kit that I bought, all the gauge wires aren't included and some aren't long enough, for that matter.
Although...since you are going water cooled, the "Water Temp Sender" wire would look better in your Baja. :lol:
Skidmark
Post by Skidmark »
I will take some pitures tonight when I get home from work...
DesertGuy
Post by DesertGuy »
Skid, it is good to know about "what is" and "what is not" included in the kit, thanks. I downloaded the instructions and I am interested in the ignition set-up also. So let me know wizard when you get it hammered out.
One thing about all this electrical jazz is, it all adds up very fast. I just dropped $200.00 for toggles, a couple of indicators, and a horn. Speaking of horn, which one did you get? I ended up with the Hella Supertone.
Skidmark
Post by Skidmark »
Horn? What horn?! Oh jeez...
Here are a couple shots of my crappy wiring. It will look better after I put the power braid on it... All of the gauges that came with my car had connectors already crimped on the light and power wires. Since I want the gauges removable (if necessary), I kept those connectors intact. It makes the loom look like crap, but again it will all get covered when I finish the wiring...
And yes, there are bare wires hanging loose in the picture... I have not hooked up the signal wires to any of the gauges yet since they are a part of the Painless harness. This is after finishing just the common grounds, lights, and +12v wires...
Tim - do I need help with posting pics?! C'mon dude... it's not like I haven't put up any pics on this site before... :shock:
MNAirHead
Post by MNAirHead »
I'll do anything to make it easier to stick around STF. Pix are worth a zillion words.. you're now a member of the hall of fame.
CopperBaja
Skid,
You forgot to cover up the hole for the old fuse panel....or are you going to use it for something?
Looks alot like my progress. What are you going to cover it with? What's a power braid?
I was thinking of one of those big plastic covers or something like that.
What are the options?
