I have almost completed re-wiring my entire buggy from scratch. Thought it couldn't be too difficult, I wish you guys had warned me. Anyway...I cannot get my signals to work.
I do NOT have a stock signal switch, I have two illuminated toggle switches to the left of the steering wheel. Can anybody give me a hint as to how this should be wired? I have an original beetle shop manual and wired it as close to stock as possible, obviously splitting the power to the switches to supply both.
Marker/running lights are hooked up, seperate circuit. The switches have three terminals, supply, load and ground. Supply comes from the flasher and load goes to the light. Ground is self explanatory. I am using a two terminal electronic flasher, so it has power in and power out.
Right now when you flip the switch, toggle lights up and marker lights dim. Signal light does nothing.
Signal wiring...sorry if this repeats i am new here
72lowridebuggy
- Speedy Jim
72lowridebuggy
- Speedy Jim
72lowridebuggy
72lowridebuggy
