alternator help
nitros69bug
alternator help
every time i start my 69 bug the volts will be at 11.8 and i would rev the engine than the volts will go up to 12.8 and stay for a few min than go back to 11 volts than go back to 12.8 volts but when i bought this alternator it would charge at 14 volts how can i fix this
- 72bajaben
im kinda confused as to what your saying.
i understand it as, it use to charge and 12.8 volts and you upgraded to an alt and now it is at 14 volts?
if this is the case then there is nothing to fix it should be at or around 13-14 volts. i have seen mine go upto 15 before.
but maybe im not seeing the question right.
nitros69bug
nitros69bug
- Speedy Jim
nitros69bug
Ok my pioneer deck has a volt meter. so i replaced the alternator when i started the engine it was at 11.8 volts than i rev the engine to 4,500 rpm the volts went to 13.8 than after driving it a bit it stayd at 12.3 volts even when i rev the engine. So i put a big ground on it and a big charging wire and if i pull off my wire going to the speedo the light does not turn on. could that be the problm yah and when i take off the pos post after a cuple seconds the car will die. thanks to all CHAD
- Speedy Jim
nitros69bug
nitros69bug
