Gus is a 1972 Ghia.
I bought Gus on Friday of last week. He ran fine. I left the hood open Friday night. Ignition was off. Started the car Friday night.
Replaced the lights in the car Saturday morning. Tested the lights and they all worked. I then cleaned out the car, leaving the doors open. No interior lights in the car, so no battery drain that way. I did not leave the key turned on long without starting it. While the key was on, there was a clicking noise from the engine. I thought that this was the fuel pump.
I went to go to the store, and Gus would not start. Nothing. No turn over, lights or anything. A friend tried to jump start it because I thought I might have drained the battery. Nothing.
I bought a new battery, today and a volt/ohm meter. I tested the old, battery while still in the car, and it is showing 12 volts and 2.32 amps. At least that I what I remember the amps were. I tested the new battery, while it was sitting on the floor. It tested the same as the one in the car. Thus, this rules out the battery issue.
Could it be the voltage regulator?
I just moved to the area here and do not know where to take Gus, so I thought I would try to troubleshoot the electircal myself first. Might save some $. Besides, I work for the power company and it would look pretty funny if I had to take it somewhere for an electrical issue. hehe.
Thank you in advance, Kim
