MNAirHead
Posts: 9570 Joined: Mon Sep 08, 2003 6:12 am
Post
by MNAirHead » Tue May 29, 2007 9:24 pm
Last year I parked a great AZ bug.. then decided to hide the key so well nobody could find it.. (including me)
Any tips or pointers on testing this car's starting abilities?
I'm aware later bugs you could start after taking the key portion of the ignition out and use a slotted screw driver on the plastic switch
T.
Speedy Jim
Posts: 2290 Joined: Sat Feb 15, 2003 12:01 am
Post
by Speedy Jim » Wed May 30, 2007 7:36 am
Jumper coil from battery like so:
Then jumper the starter (Shift in Neutral!!)
If difficult getting underneath, find the Red wire under the back seat
and jumper to battery post.
MNAirHead
Post
by MNAirHead » Wed May 30, 2007 3:50 pm
Thanks speedy..
Chances are I'll be pulling the tumbler after ward.
My intial thought was to hot wire it.. wanted to triple check there wasn't an easier answer.
Tim
Speedy Jim
Post
by Speedy Jim » Wed May 30, 2007 4:07 pm
Welllllll.....you could do like we used to with old Fords -
Hold a quarter under the ignition switch terminals.
Hold the coin one way to complete the coil circuit and
then touch it slightly to the starter contact.
