MNAirHead
Post
by MNAirHead »
Speedy Jim wrote:1) The battery is located where it is so that the heavy cable run
to the starter is as short as it can be..
2) The only wire in the Main loom that sends an actual Ground signal
is the Oil sender.
The generator/alternator (Blu wire) sometimes sends a Ground
and (when charging) sends a +12V signal.
The Flasher relay sends a Ground (kind of) to the speedo indicator.
The Fuel sender sends a "quasi ground" to the Gauge.
For accessories, the Horn button sends a Ground.
The Interior light door switch sends a Ground.
Speedy Jim
http://www.nls.net/mp/volks/
Post
by Ol'fogasaurus »
None of the wires sends a + or - !
Speedy Jim
Post
by Speedy Jim »
I forgot one
The headlight dimmer lever sends a Ground to the dimmer relay.
MNAirHead
Post
by MNAirHead »
Thank you for the information.
I believe this was going to be used in conjunction with engineering a grounding bus
