Here is the rest of the step cut off. Have to do a little metal work here too before the dogleg goes back on. The floor needs some also which will be done too.
Here I had to bend the floor back to get the grinder in there to get the welds ground down.
After I test fit the dogleg I realized this bracket was in the way of it going the whole way on.
Another pic of the bracket.
Since the original dogleg didn't have this bracket I decided to just cut it off.
Here is the dogleg test fit into place.
Another pic of it in place. Note the floor work needing done.
As you can see it is going to need some work to get it where it needs to be. you can kinda see the gap at the back in this pic.
Another closeup pic of the front. Fit is pretty good here.
More to come. Please check back.
Geno
