fastback
Posts: 1670 Joined: Wed Sep 12, 2001 12:01 am
Post
by fastback » Fri Aug 17, 2007 3:45 pm
Got my hands on a set of these vintagelookingblisterpack of bigfoot lifters.
Pretty heavy , but makes the camchoices a bit more.
any good?
Oil groove could be better..
more info appreciated.
fastback on Fri Aug 17, 2007 4:10 pm, edited 1 time in total.
Unkl Ian
Posts: 872 Joined: Sat May 25, 2002 12:01 am
Post
by Unkl Ian » Fri Aug 17, 2007 4:06 pm
The old lifters typically were much better than the newer stuff.
Rolf
Posts: 298 Joined: Fri Sep 14, 2001 12:01 am
Post
by Rolf » Sun Aug 19, 2007 3:49 am
They are HEAVY, like 141 grams !!!! 5o grams more that a stock lifter. They need strong valve springs to prevent them from bouncing on the cam. I have seen them in a type 4 engine that was used for dragracing and the cam went flat/broke within a few runs. The lifters and cam looked REALLY bad. But for a street engine with moderate cam choise and good strong valve springs the lifters can be used.
Just my 2 cents
/Rolf
fastback
Post
by fastback » Sun Aug 19, 2007 2:13 pm
i'll test them in WBx that has OK dual springs and maybe a TCS-20 cam..and turbo ofcourse
but'ill make the oilgrove a bit bigger.
fastback
Post
by fastback » Fri Aug 24, 2007 12:50 pm
yes i noticed
148 Grams before removing some material.
i also put a hydraulic lifter ,filled with oil, on the weight: 117Grams
fastback
Post
by fastback » Tue Nov 25, 2008 12:37 pm
Hey Rolf
Would u mind check if your friend has one or more of these lifters still laying around??.
and if they could be re-used with a regrind?
had an accident machining one of them..
Rolf
Post
by Rolf » Thu Nov 27, 2008 8:21 am
Hi Fastback
I will ask around if anybody still have contact with him, he vent out of the VW hobby years ago. I'll be back later.
/Rolf
fastback
Post
by fastback » Thu Nov 27, 2008 8:36 am
great
SiQDiZ
Site Admin
Posts: 266 Joined: Mon Oct 29, 2007 1:13 pm
Post
by SiQDiZ » Thu Nov 27, 2008 12:35 pm
mind you that the hydraulic standard lifters in the WBX are filled with oil, so that adds additional weight to the original lifters
tencentlife
Posts: 424 Joined: Tue Apr 25, 2006 8:13 am
Post
by tencentlife » Sun Nov 30, 2008 10:28 am
True, a few grams. The volume of oil inside the lifter couldn't be more than 3cc, and oil is lighter than water.
fastback
Post
by fastback » Sun Nov 30, 2008 10:51 am
fastback wrote:
i also put a hydraulic lifter filled with oil , on the weight: 117Grams
yes
Rolf
Post
by Rolf » Wed Dec 17, 2008 7:47 am
Rolf wrote: Hi Fastback
/Rolf
Fastback,
No luck in finding this guy, sorry !!
Have you asked CB Performance?
They might have some left overs.
Just a thought
/Rolf
fastback
Post
by fastback » Wed Dec 17, 2008 7:57 am
thx for the effort rolf.!
I'll see what i'll come up with... but i have more or less trown away my plans with these anyway..
Rolf
Post
by Rolf » Wed Dec 17, 2008 8:01 am
I hsve used some of Udo Becker lifter sleeves for type 1 lifters in a friend's oxyboxer and they works fine. I have made a drift to install them with and when the sleeves was cooled in the freezer and the case was heated a little bit they went in like a hot knife in butter
/Rolf
