Negative cable placement.
mech361
The chassis is a convenient ground plane and that is where VW usually first put the ground cable, then to the engine. Americans usually put the ground to the engine block, then to the chassis. When I can, I like to run the ground to an engine/transaxle bolt then to ground.
Which ever you do, check the connections for a good ground. Chase threads in threaded connections and chase bolt threads to make sure that you have shiny metal to use as connections. If there are welds in between important areas that you want to use as grounds, check for continuity on both sides of the weld.
