fire prevention
- bugman742002
fire prevention
the guys over on the bus barn have a few good suggestions that also could work on bugs as well. if anyone has any more ideas please post them.
1. replace all fuel lines.
2. make sure all hoses are secured with clamps.
3. reroute the live that goes from the pump to the carb.
on stock engines, the fuel line fitting on the carb gets loose sometimes and pops out, spraying fuel all over. You can use a narrow headed punch or a dull chisel and a hammer to peen the surrounding casting tighter against the pipe fitting to secure it in place. Also you can tie down the fuel line so it can't back out even if the fitting did get loose. Only minor leakage would result.
And never put a filter between the pump and the carb. The added weight of a filter full of fuel, floppingt around as you drive, sends tugs and jerks up the line, to the carb top fitting.
Jan
Jan
- bugman742002
- Kenny2428
Good suggestions guys. Also, always carry a fire extinguisher! Another wise suggestion would be to inspect, and replace your fuel line every so often. Also, check under your back seats and see if the battery is in danger of shorting out on the springs on your back seat. Had this happen to me once, but luckily I caught it before it caught fire. Another thing to check is the rubber grommet on your fan shroud. Check to make sure it isn't cracked. If it is cracked, over time your fuel line will rub back and forth on the shroud, causing leaks. Btw, I will make this a sticky.
- bugman742002
- bugman742002
- bciesq
I installed a metal line to go through the front firewall:MNAirHead wrote:About 1/4 of the bugs I tear down have rubber lines going all the way from the tunnel outlet to the fuel pump..
Where it passes through metal, there is metal tube.. not rubber... check it out.
http://www.aircooled.net/new-bin/viewpr ... d2=THH0008
and added a grommet for the hole:
http://www.aircooled.net/new-bin/viewpr ... d2=THG0001
Total cost ... about five bucks.
- vw-in-neptune
