no cig lighter ,now what?
65NSunnyAZ
My 65 vw beetle is doing great. I just installed a system and have just one question. Of course there is no cigrette lighter, and I just bought a bright neon light for the box. My question is how do I make it work.?The stupid thing only came with a cigrette lighter adapter. There is only two wires. This has got to be an easy question for my vw forum people.
. Please help I'm stuck.
- david58
- rickosuave1987
It doesnt make a difference which side is hooked up to what. Since cars are DC (direct current) the leads can be hooked up either way.
Depending on how you want it to work, hook one side to a hot with a switch in line and the other side to a good chassis ground.
Baja
HookIt
SuaveRacing FaceBook
HookIt
- david58
Most cig lighters are metal and go into metal so it does matter, because it will be a direct short if the body of the lighter is hooked to the pos side.rickosuave1987 wrote:It doesnt make a difference which side is hooked up to what. Since cars are DC (direct current) the leads can be hooked up either way.
- rickosuave1987
Yes. you are right. But he doesnt want to wire a cig lighter. He wants to wire a neon light....
Baja
HookIt
HookIt
- david58
Yeah I re-read the thread.rickosuave1987 wrote:Yes. you are right. But he doesnt want to wire a cig lighter. He wants to wire a neon light....
65NSunnyAZ
1st of all, thank you for responding. I really listen to the posts and enjoy using this forum. My 65 bug is currently on a 12 volt system. I have converted everything even the electrical on the 6 volt tranny I still run. The neon light is a bright deep blue color, the one thats 10x brighter. I'll show a pic as soon as I get it working.
Accually I am pretty exicited to hook this neon light up allreadly.
