On a CB drop-spindle balljoint front with disc brake?
Thanks.
Somebody just GAVE me some 14" mini-lites!
WhooHoo!!
Was thinking of putting some slicks on them and going to the local autocross...
If they'll fit, that is....
can I run 14" rims?
- Clatter
can I run 14" rims?
- crocteau
Clatter, I confess ignorance about mini-lites, but I think you'll have issues. I saw barely 1/8" clearance between the lower ball joints and 15/5.5" Fuchs on CB 2 1/2" drop-spindles I tried on my Ghia beam, and the lower ball joints were the new ones without the grease fitting. Someone else may be able to tell you about caliper clearance.
- petew
just wack em on see. you can always clearance something as long as it's not structural.
aka "slowlearner"
http://drivingnotpolishing.blogspot.com.au/
- Clatter
Yeah, I tried them on, and no luck...
It would be a sweet combo, but it all makes sense why it won't work.
Maybe I could find a set of Jatechs or something that had a smaller drop..
- petew
sorry mate. that's the best way to find out. keep on searching.
aka "slowlearner"
