Cam choice for my 2.7l T4 engine
VW1300-NORWAY
Post by VW1300-NORWAY »
What cam do you recommend for my 2.7l T4 engine (Race/street engine) ? (I am looking for something like a Web 86C cam).
Specs :
78,4x105mm
Heavily ported heads with 48x40mm valves.
Comp. = 11:1 (99 octane gas in Norway)
48 Dellorto carburators
Thanks,
Geir
dstar5000
Post by dstar5000 »
Jake's 9650 +5 is a good large displacement cam.
Don
VW1300-NORWAY
dstar5000 wrote:Jake's 9650 +5 is a good large displacement cam.
Don
Hi, and thanks for your reply!
Where can I find more info on Jake's camshafts?
Thanks,
Geir
Gäschen
Post by Gäschen »
34plus2
Post by 34plus2 »
2733 (82x103)
48 idf / 009
schleicher 324 (9,7mm lift at the cam) w 1,48 pauter
max torque at around 4000
around 215 ft/lbs, 205 hp
but you don`t need that much lift, stock rockers are fine.
this was a nice street / race combination.
Post by MASSIVE TYPE IV »
All details here including a link to my very extensively prepared cam and valve train presentation..
I only sell cams with "kits" of compatible parts.
http://forums.aircooledtechnology.com/s ... php?t=1929
Gäschen
Post by Gäschen »
[quote="Gäschen"]Hei
Har du sjekket her?
http://www.aircooledtechnology.com/store/[/quote]
I do have a 78x105 engine myself. Ended up with a cam from Pauter, on the third combo.
One and two went flat, so I bought the ceramic lifters and the Pauter cam.
Jake Raby som jeg linket til over her selger kun kammer til kmpl. motorkit. Synd.
Eurorace og Web cam som var de to første kammene gikk beklagligvis flate. Selv om det ble brukt "lube a lobe" løftere på kombinasjon to. Ellers skulle de kjeramske løfterne være "uslitelige". Gjenstår å se det da, har ikke åpnet motoren siden. Mener å huske Pauter kammen var på 268 grader ved en 1,27 mm/ 0,050" løft. Tror den løfter rundt 13,5 mm. Dette drar til opp i mot 7000 o/min. Toppene er fra Mark Stephens og har 48X40 ventiler. Vet ikke hva de flower da. Mener den bremset 166 hk. ved 5002 o/min, da fløt ventilene, og da var det ikke mer å hente. Dette var med kam nr, to.
benito26
Post by benito26 »
c'mon man english translation would be helpful here, we are all sharing info.
eugene
Post by eugene »
The cam that Wally used in his 2.7 could be a good candidate.
Wally, where did you get that came from? I'm will be probably looking for a new cam soon and my idea was to use something similar (split duration) but wit less duration overall.
Wally
Post by Wally »
It was a custom split lift/duration cam from some 10-15 years old I bought from somebody's old stock. Sorry. Besides, its in 3 pieces now...
BrockGrimes
Post by BrockGrimes »
78mm Scat crank
103mm cylinders
mahle pistons
stock 2.0 type 4 rods
Edelweiss motorsport 324/332 camshaft
46mm and 39mm valves
2 weber IDF 48's
200+hp
VW1300-NORWAY
Hi, and thanks for your replies!
I've been recommended the Pauter O3N8 cam.
What kind of lifters do I use for this one?
Geir
VW1300-NORWAY
Here's some pictures of my project :
Heads before :
VW1300-NORWAY
Here I've started porting...
VW1300-NORWAY
Exaust port before...
After ;)
Exaustport (from chamber)
