painting a sand rail frame.
- ChadRat
I have a sand rail frame that is bare metal. I need to paint it. Can I get away with one kind of primer and some single stage paint? I would like a nice durable finish but it does not have to be show quality. Any suggestions on what kind of primer or paint to use? How much primer and paint will I need? How many coats of each? Thanks!
- MNAirHead
I've tried just about every type of direct to metal finishing out there..
Overall.. I'm a huge fan of Zero Rust (www.ZeroRust.com).. it's about $50 per gallon.. dries slow.. can be thinned with just about solvent.. looks like powder coating when done.. and comes in colors.
3 coats... there's a balance between protection and chipping.
- bajaherbie
chad, are there any Attwoods stores in okc? they sell a line called
Van Sickle implement paint that works good but comes in basic colors like john derre green, catepillar yellow and International red, etc. some nice whites and a few others also but no purples. the primers are really good too. i'd say a quart or two of primer and a quart or two of top coat.
our local uh-o'reillys is the dupont retailer here, you could always ask the 18 year old kid behind the counter for some advice...
BUILDER
painting frame
chadrat, you can try a metal etching primer such as DuPont variprime. This etches the metal (bites in), will prevent rust, and give you a solid platform to start with. I would recommend a urethane primer sealer over the variprime but some will paint over the variprime without problems. Other manufacturers have similar product lines.
- bajaherbie
MNAirHead wrote:Is van sickle a direct to metal barrier type material?
uhhh, i think so.
- pafree
ebay has a etching primer, no one sells van sickle by me. do you think this is simular. http://cgi.ebay.com/ebaymotors/1-Gallon ... 0179399171
