8mm head studs or special case savers
Rolf
Post by Rolf »
Hi,
I'm looking for some steel case savers/inserts for a oxyboxer project. I would like to use 10 mm head studs and need some thin wall thread inserts to fit the M12x1,5 mm thread in the case and have M10x1,5 mm for the head studs. Any idea where to get them?? Or should I just buy normal type 1 case savers and use 8 mm head studs?? The engine is a 86x102 mm monster with JP Motorsport heads FK89/98 cam etc
/Rolf
carsten bb
Post by carsten bb »
I think timesert og helicoil will work. (dont remember excatly whitch..) check with you lokal tools supply. This is what we bought for this opperation for a 101,6x76,4 Fk89 jpm heads WBX engine that is in the works.
