Here is a pic of the hood of my project 65 'looker. As you can see she is wearing an empi style hood. It's not a real empi hood, it's a later replica. The fit is not what I want, there is a gap on both sides that the hood is centered between and there was no mounts for hinges, so the PO installed it with dzues fasteners.
The deal is I want to remove this hood and install a steel 65 hood, and in the process get hinges and a hood locking mechanism back. However, I also want to cut the styled depressions out of the 'glass hood and install them in the steel hood. My bodyman says this is do-able, but I want to understand the process so I know what needs to take place.
How do you merge steel and fiberglass? Will resin hold it or do I need rivits?
On a side note, the pic is misleading, the paint looks good from 20 feet (or on a phone camera) but I am hardly cutting on a "clean" car, there will be a respray after everything is done.
