Air Compressor Purchase Advice.
TechnicalNut
Post by TechnicalNut »
Hi Folks,
I'm just after a nod to say this compressor will be ok for shot blasting the underside of my bus and applying paint before I purchase:
v-belt driven, 3hp motor (1hp continuous), 14cfm, 150litre, 10bar/150psi max pressure - (doesn't say if it's oil less or not - I'm not too sure what the merits of either are tbh!)
http://www.machinemart.co.uk/shop/produ ... -000110140
Thanks in advance,
TechNut,
UK.
That size commpressor is a good size.
doc
Site Admin
Post by doc »
I suspect this will be about the minimum unit for painting whole vehicles. And you will do some waiting while the compressor catches up with your sanding tools and grinders. I have a compressor just slightly smaller and it will just limp by big jobs. But, here in the states, the next step up basically doubles the price. And I don't do very many paint and body jobs.
doc
MNAirHead
Post by MNAirHead »
you should be able to keep up on a gun.. the next piece is to check the CFM requirements of your paint gun.
tim
MNAirHead
Post by MNAirHead »
Note..
I used to have a horizontal air tank.. took up a ton of room.
I switched out for an upright with wheels.. now can bolt it to the floor when needed and move it around without some pals.
T.
stephenriley
Post by stephenriley »
Mine is a similar size and copes fine when spraying and using air tools. I used it for media blasting when I restored a Morris Minor ( I used an eastwood pressure blasting pot) It worked but was just about at it's limit and i had to give it a rest now and again to stop it from running continuously which would probably have caused some damage if done for long periods.
Stephen
