This car used to be raced back when and showed all the signs of it. Bent rear torsion housing, bent front beam, rear deck completly cut out, dash cut out, and the list goes on and on. The cage in the picture ( it arriving home ) was made out of I don't know what, and welded poorly. The cage got into the doors, so they cut the inner door out to accomadate the cage. Really the only thing left of the car is the body....By all means let me know if you see me headed the wrong way,
I welded in a dash and a rear deck, from here at least if it needs it I will cut it instead of using a hatchet.
I put in a loop to help hold up the heavier Ford powerplant, and thats where the cutting begins.
Not having a good time with the Class 11 cage, think I am going to scrap most of it and bend my own main bars.
More random pics of the progress so far.
