Can i use a Type 1 threaded plugs kit based for a type 1 on a WBX or are the sizes different?
like this:
http://www.thesamba.com/vw/classifieds/ ... ?id=575469
threaded plugs oil galleys WBX/Oxy
- sideshow
The sizes are what ever you drill.
That doesn't seem like a bad start, steel plugs and all. But what I observe is that you may need two 3/8 taps to make a couple of the holes (a shallow tap doesn't require a deeply drilled hole).
Now the big question is what style taps are available to you? NPT (national pipe thread) or BSP (British Standard)
- fastback
