The engine has an intermittent problem where it will be running fine and then suddenly starts stuttering when cruising.
If you ease off the power it is smooth and if you accelerate it picks up smooth. Whilst cruising at one speed it sounds like it's missing and then occasionally picks up speed and then is smooth again
I took it to a rolling road and of course it behaved itself. The tune up went with no hitches and the drive home was fine.
Took it out next day and after 30 mins of driving it started playing up again.
Today I drove to work and back. It was fine until just arriving and then started again. Coming back home it did it from a cold start all the way.
So far I have changed:
Fuel pump.
Hall sensor.
Distributor cap.
Various HT leads.
The carbs are reconditioned.
The main and idle jets were changed during the tuneup.
I have ordered a new coil and rotor arm but it does not sound like an ignition problem.
I just can't see a pattern that would cause this?
Any ideas people?
