epoxy primer.
Passatman
epoxy primer.
Post by Passatman »
Is epoxy primer and your paint application enough to put under your wheel wells and fenders.
MNAirHead
Post by MNAirHead »
You'd also want some enamel (single stage) paint..
The material should be about as thick as egg shells when totally done. Chips frequently are from thick brittle paint.
I commonly will use a rust encapsulant under the wheel wells... I like to do mine black to make them easy to touch up.
T.
Passatman
Post by Passatman »
I had por 15 under the wheel arc but i now see where i have some spots lifting so i am going to sandblast it out and start again this time with the epoxy primer.
MNAirHead
Post by MNAirHead »
POR etc should adhere under the wheel wells.
How did you prep the steel?
Tim
Passatman
Post by Passatman »
Well what i did was to use a wire wheel in my drill to first remove all old paint then i used osphor to etch and also to provide an antirust protection the por15 was then placed over the bear metal.
MNAirHead
Post by MNAirHead »
POR is supposed to have some flash rust...
Normally you remove all paint.. then shoot some salt water on it to let it flash rust.
Passatman
Post by Passatman »
This little fact is news to me. Well my mind is made up i will be removing the por15 it didn't bond well to the metal, but i think the epoxy primer will be better.
MNAirHead
Post by MNAirHead »
ON show cars we use etching primer.. sealer.. then single stage enamel...
On driver cars a rust encapsulant.
Adhesion is mostly prep.
