Camber Compensator
beetlecharles
Camber Compensator
Post by beetlecharles »
I was wondering if anyone had had any experience using a camber compensator on a '67> swing axle Beetle equipped with a factory Z bar.
Two designs are available as below:
I would like to know which would be best suited to my application of a '72 1300 Beetle on which I want to retain the Z bar? Do either of the above foul on the Z bar cups which are attached to the axles?
Thanks. :D
Its a UK spec car BTW hence being a '72 model but still having swing axle rear suspension.
beetlecharles
Anyone?
Even just a photo of a CB performance compensator fitted to someones car would be a great help.
Thanks.
MinamiKotaro
Post by MinamiKotaro »
My '67 has a camber compensator, but the Z-bar is removed. It went from handling so poorly I was afraid to turn the wheel to being planted.
'67 Beetle, 2276
MS-1 v3.57
