Unfortunately the pics are not in order however I hope everyone gets the idea.
Out with the 84 Mexican pan, swing axle, and reliable 1200.
In with the 74 IRS pan with 2110
A few lessons learned along the way.
1. Before you buy something as a newbee ask for advise. I would have saved a lot of time and money if I had done this. I have lost count of the times I have ordered something that is not compatible or not of good quality because I did not ask someone with a lot more experience.
2. EMPI HPMX – do not do it. Take your time and find the webers, Italian if possible. Although Mark Harney did an awesome job rebuilding my brand new HPMX’s I would have saved a lot of time and money doing it right the first time.
3. If you want to go Fuel Injection. Be patient, save your money, do you homework and go FI. I went the HPMX road with the intent of upgrading later. Not the best move.
4. If you want to go turbo see #3. Initial build up is the time to choose cam, heads, compression ratio, and exhausts, not after you just blew $3k.
5. Exhaust, save your money and order ceramic coated. Do not buy a $600 kit only to find it tooo loud for a daily driver and rusted after 6 months. Its cheaper to order one already coated than to coat one that is not.
6. While the car is ripped apart. Be patient redo all bearings and bushings. I did not and may have damaged my new rear disk brakes. More to come. While your at it redo the wiring with something like the Watson kit. I did not and was left stranded on the side of the road three time due to electrical gremlins. For what an Auto electrician cost me to piecemeal my original system I could have purchased a new kit. I would have learned where every wire goes and I would have a lot more attention to detail in the installation. Not the rats nest I have now and still have to order the Watson kit for $350. think of it as insurance, especially if it’s a daily driver.
7. Chalk white Square-weave interior looks cool but is not smart on a daily driver. The TMI Square-weave has started to crack badly after only 2.5 years. I just order the Sand colored tweed kit. I will keep everyone posted as to wear and practicality.
8. Be Patient, Be Patient, Be Patient, ask for advice, do your homework and do it right the first time.
I understand first hand that somethings will be necessity driven that the car has to be back together by Monday morning to go to work but everything I did in a rush has had to be done over.
