Rear sway bar install
Posted: Sun Aug 31, 2008 2:24 pm
by bigmeat
What does one have to do to install a rear sway bar on a 70 Standard Beetle?
Rear Bar
Posted: Sun Aug 31, 2008 9:00 pm
by FJCamper
Hi Bigmeat,
There are two common rear sway bar mount setups, one in which the bar is held to the chassis by a clamp arrangment, and one in which you have to drill holes in the frame horns and slip in "U" bolts.
Whiteline, for instance, uses clamps. AddCo makes you drill holes.
There are also different ways to attach the end of the bar to the shock bolts, but these are minor.
The important thing is to first have a front bar as thick as if not thicker than the rear bar. A rear bar really changes a VW's handling, making it respond much quicker to changes in direction.
Too much front bar and you just understeer. Too much rear bar and you leave the road backasswards.
FJC
Posted: Sun Aug 31, 2008 9:23 pm
by sideshow
I can't say what brand I have (second hand from a swap meet) but the one I use has this style round clamps that attach to the torsion housing. It is rather fast to install, just add an L bracket to the swing plate and connect the down links.
http://www2.cip1.com/ProductDetails.asp ... C-C10-4034
Half hour at the most, rear end on jack stands, hand tools.
What to Wear With Ugg Boots
Posted: Tue Jan 20, 2009 6:52 pm
by seoceo2008
Ugg boots are available in many different colors and styles and it is this enormous selection which makes the boots so versatile and desirable. The styles run the gamut from the casual look of the standard three quarter boot in a natural shade to the flamboyant and funky long haired pink boot. Whatever color you can think of, the sheep skin can be dyed to match.
People are wearing these popular boots to the office, on the dance floor, out to dinner, and while on vacation to the slopes or to the shores. Whatever doctorate online you are trying to achieve, you can achieve it with uggboots. And these boots are not geared towards any one segment of society. Men, women, children and infants can all find a pair of cheap ugg boots to match their size and their style.
Think wearing boots at the beach sounds crazy? Well, this is what surfers did back in the seventies. In fact, even though sheep skin boots had been around for quite some time, it was surfers who started the craze. Australia is a great place to surf, and since doctorate online boots are made from Australian sheep skin their existence was already well-known in the land down under. After emerging from Australia�s cold ocean waters, surfers needed something which could quickly warm their feet. They found their answer in uggs. These boots became as essential a part of a surfer�s gear as a surfboard. As Australian surfers traversed the globe in search of the perfect wave, they took their boots along and in no time at all, the popularity of the sheep skin boot exploded.
Ugg boots that are made from genuine sheep skin can be worn in all types of weather. When one thinks of boots, one tends to relate boots to cold weather. While it is true that these boots will online interior design course feet warm in temperatures as low as 30�F, the sheep skin encourages air circulation which helps to keep feet cool even as the ambient temperature climbs. The natural wicking action of the sheep skin draws perspiration and other sources of moisture away from the skin.
These boots are comfortable, too, fitting as snugly as a second skin. And because they are comfortable, people are wearing them everywhere with everything. The styles of ugg boot range from tall to short and everywhere in between. There are clog styles and slipper styles. Tie up online computer course top-stitching, buckles and snaps are just some of the accessories that can be added to these boots to change the appearance. There are styles for achieving an ultra feminine look or the rugged mountain-man look. Uggboots are available in black, brown, brown, blue, purple, red, natural, gray, off-white and more.
So break out of your fashion rule mentality and let your imagination go wild. Get yourself a pair of ugg boots and wear them with you jeans, wear them to work on casual Friday, or pair them up with your online interior design course best. Wear these functional yet attractive boots in daily life and even while on vacation. If celebrities can wear them during breaks in filming and children can wear them to school, and if Aussies can wear them out in the sheep shearing sheds, then you can wear them too.buy ugg boots .
Re: What to Wear With Ugg Boots
Posted: Wed Jan 21, 2009 6:51 am
by Ozzie
seoceo2008 wrote:Ugg boots are available in many different colors and styles and it is this enormous selection which makes the boots so versatile and desirable. The styles run the gamut from the casual look of the standard three quarter boot in a natural shade to the flamboyant and funky long haired pink boot. Whatever color you can think of, the sheep skin can be dyed to match.
Wake up Dave!
Re: Rear sway bar install
Posted: Wed Jan 21, 2009 7:49 am
by turbobaja
bigmeat wrote:What does one have to do to install a rear sway bar on a 70 Standard Beetle?
Here's a link that might be helpful with your rear sway bar install.
http://www.shoptalkforums.com/viewtopic.php?t=122462
