Headstuds WBX
- fastback
Headstuds WBX
Is there any stronger headstuds available for the WBX??
- fastback
Do you get case savers / thread insert from M12 to M10?
maybe not enough material to do this.
since the crankcase side has M12 threads, i was thinking of getting 12mm studs, then machine them down to 10mm diameter in a lathe and make M10 threads on the top.
cause if i first do thei job i want to not just go from 7mm to 8mm but be on the safe side.
So any tips where to get misc studs in fine thread M12 various lenght's appreciated.
12.8 12.9 grade steel will do i asume
I was going to look at this with a UK co that makes whatever you want... should be able to do something corrosion resistant too... the problem I can see is the studs could be too strong.. maybe?? I think they need to "give a little"
Do they need to be stronger? use new ones in a hi po engine... I seem to recall Marco only used stock ones in his monsters.....
- fastback
- fastback
the HP is in reach for shure.
i'm currently stuck at 343Hp today on a 2,2
with stock heads.
I have not any pistons yet, but JEpistons will get that job.
compresion will not be a problem. i'm not going for 7:1 maybe around 9:1
runnig e:85
not decided if i go for 99 or 98mm bore.
must do some measuring on my cylinders first.
and with the DPR 82 crank it will be 2,5 L
runnig e:85
I have a set of NOS Oettinger 2.5L 98mm. pistons.. that wont go in a stock cyl.... (I cant see how there is enough material for the GW 97.5's.....) and the case has to be machined too.. its actually quite a bit of work and I can see why Oetti were so costly.. I too am after an 82mm from DPR...
The Oetti pistons are very thin on top.. no way to machine much less CR.. (9.7) and I doubt would withstand a turbo... They are nice though...
We should talk.. could be poss to make a piston for yours and mine.. (was planning on building a few 2.5's) just machine a bit more out for yours
- fastback
yes custom sleeves.they are from a Volvo diesel engine if i remeber correctly. very long and has to be machined for length and diameter.
Theres no free lunch , so machining of the case and heads must be done of course, but that should not be a problem.
Regarding stock MV pistons , and the 96mm Wisecos form Gowesty , they have handled 1,25-1,3 bar so far.
Here's the MV piston
