I ran into a little problem today. I am assembeling my 2.1 WBX converted for solid T1 lifters.
Today putting together the two halfs I had problems droping the lifters attempting to put the halves together. For preassembly the oil could hold the lifters with no problem, so I was quite surprised by this new problem. Finally I figured it would help if I held the lifter with my fingers and a magnet. I got the two halves put together and started torqing the nuts when I saw a small piece of metal lying in one of the lifters. http://gust.dk/billeder/main.php?g2_vie ... alNumber=2
My concern would be if the material isnt great, then are they going to survive for long....
I have pulled a couple of engines apart and the (hydro's) lifters had chips and lumps and even the circlips were missing from a couple... no evidence of the bits though
Yes the lifter got dropped. One went to the floor but I don't know if thats the one that broke. I would suspect that material is allright but that if it has it's first crack it might have cracked in different places too...
/Mads
I ordered new lifters at CSP, though it's only Scat they are proberbly alright for me...
And I also ordered the tool you show, so no more dropping lifters
I am not certain that lifters with a high ball seat can use the wire lifter retaining tool, you have to go lower technology.
Or a drop of heavy grease.
