4 balanced wheel,4 new tire
steering shock old but ok...
new bearing both front side
but it shake very strong when run more than 70kph with turn just alittle steering wheel, if hard turn, it smooth???
it shake until bearing adjuster loose and this synthom go wores, so i tight it back to position, just 2-300 km it loose again..........
all standard parts, only 2" cut spring at front and down1" torsion adjusted at rear
tire 195/60/15 front 205/65/15 rear.
before this it always shake but i balanced front wheel on car it better,
i found that front brake disc have small excentric so i change all front disc, seem better, but i still don't balances on car, cuz i thing that all problems shoude be gone with that disc... but it not, it be only 2-300 km as i said....
so any point that i neglet...
please advices.
another point is my bug run smooth onlw lower than 90kph, at the same road, if faster it will bug impact by the road, i just change new rear shockup to sach standard shock cuz alot cheeper, seem alot better, can drive to 110, i can feel that front wheel still be problem, but i'm not so sure that spring or shock is the root,
i check new rear shock it look like only one action for rebound, not have action for bump, but old shoch have 2 action both bump and rebound.
I check with my spare front shock it have 2 action too, so should i change to new that have only one rebound action as my new rear shock.
I use this bug for 5 years, before this suspension and wheel shake is OK for me, but my daugther just born, so i need very smooth bug for her and my wife. that why it go so big now
please, thanks in advances.
