mig welder
Passatman
mig welder
Post by Passatman »
Hi All,
I want to buy a mig welder to use at home but i don't know the right specs, can someone assist me. I know miller is a good brand so it would have to be in the miller brand of mig welder also with sheilded gas.
bugdust69
Post by bugdust69 »
Millermatic 135 or 140, Lincoln 135+ or 140+, Hobart Handler 140 are all good machines.
Looking for April 1967 Coleman camping items
MNAirHead
Post by MNAirHead »
Overall three things
1-Gas Option
2-Rotating (not clicking) knobs (speed and voltage)
3-Common mfg name with a Tweeko Gun tip
74baja1915vw
Post by 74baja1915vw »
i just got the miller matic 140 and it is great for very thin sheet metal and up to 3/26" steel in one pass.
MNAirHead
Post by MNAirHead »
Congratulations.
Did they supply you with .023 wire and the correct tip?
74baja1915vw
actually it came with .030 wire one spool of shielded and one spool of non shielded wire. I have not used the non shielded wire yet. the shielded works great. I have repaired the battery compartment floor and finished installing the A piller. took me about a day to complete.
EvilleT
I got the millermatic 140 also
Post by EvilleT »
Had to mess with the settings just a little bit (turned down wire speed and lowered voltage a little from their recommendations) but after just an hour or so of practice I was welding. Perfect welds? Far from it :( but they were functional. I am only using the shielding wire no gas.
MNAirHead
Post by MNAirHead »
Just a suggestion.. next time you're at the welding supplier (get to know one .. and no a hardware store is not the place) ..
Have a sales rep demonstrate what the sound is like you want to hear for a good setup.
