VDO Gauge Wiring Link
Posted: Thu Jul 23, 2009 10:32 am
by david58
VDO Tachometer w Condensor
Posted: Sat Aug 22, 2009 2:37 pm
by Jeff Herriman
I have a VDO Tachometer that has a condensor attached to the tac body. Where do I hook up the Condensor wire? The car is a Puma with a fiberglass body. The electrics are in disarray. There are VW Brazillia parts installed but not hooked up.
Thanks for the help!
VDO Tachometer/Instruments
Posted: Tue Aug 25, 2009 5:27 pm
by Jeff Herriman
Thank you for the wiring guide. It really helps. Next will look for proper senders.
Jeff
Re: VDO Tachometer w Condensor
Posted: Tue Aug 25, 2009 5:53 pm
by david58
Jeff Herriman wrote:I have a VDO Tachometer that has a condensor attached to the tac body. Where do I hook up the Condensor wire? The car is a Puma with a fiberglass body. The electrics are in disarray. There are VW Brazillia parts installed but not hooked up.
I haven't seen the condenser on the VDO gauges that you are talking about. Could you post a pic so we can weed this out?
VDO Tachometer
Posted: Wed Aug 26, 2009 8:06 am
by Jeff Herriman
The tachometer is in the shop now. When I get it back (week +!!) I will forward picture. Its an interesting animal.
Jeff
Puma VDO Tachometer with condensor
Posted: Thu Sep 03, 2009 11:01 am
by Jeff Herriman
Re: Puma VDO Tachometer with condensor
Posted: Thu Sep 03, 2009 11:10 am
by david58
Your links don't work is this the correct pics?
Posted: Mon Oct 05, 2009 8:14 am
by Dale M.
Capacitor on back of unit really looks like something somebody has added on afterward for what ever reason.....
Dale
Re: VDO Gauge Wiring Link
Posted: Mon Mar 24, 2014 5:41 am
by madmike
Link no workie
Posted: Mon Mar 24, 2014 6:59 am
by Marc
The only logical reason for a condenser (AKA capacitor) that's grounded on one end would be as a "noise" filter.
It's unlikely that the vehicle needs filtering of the supply voltage to the gauge or to the illumination lamp, so someone must have added it at the signal lead to dampen voltage oscillations (perhaps the needle was jumping about too much for their liking). Ironically this places it in parallel with the condenser back on the distributor, increasing the capacitance of the primary circuit.
My conclusion is that if you need it at all, it should be attached to the same terminal as the signal lead coming from Term 1 on the coil.
