Use a Skill Saw with an aluminum blade works pretty well. You can clamp a piece of angle or 2x4 down to use as a guide to make straight cuts. Don't use a metal cutting blade. I have used worn out wood cutting blades by putting them on backwards.
with the proper PPE I used a table saw for the straight cuts. Carbide blade eats right through it though it does send some shrapnel, hence the PPE recommendation.
You can make numerous jig saw blades from one hacksaw blade. I like 'Milwaukee" blades. hacksaw blades also tend to run straighter than a regular jig saw blade and you can change them regularly for pennies. I agree with the oil, cooking oil works well also.
For sawing and drilling lubricant , WD-40 or kerosene works pretty well at preventing chip welding. Use a 40 or 60 tooth carbide blade at low RPM . Make sure the workpiece is clamped down. Fine tooth blades will foul up with aluminum quickly. High RPM will do the same
