Trouble with Search function
- doc
- Site Admin
The STF search function is not operating properly after the changeover. We're working to make the correction. Please use Google or similar until repairs are completed which will be announced here.
Thanks for your patience.
doc
6/26/11 - Long since fixed. But info below good as a backup. doc
doc
- MarioVelotta
Re: Trouble with Search function
Site:www.shoptalkforums.com SEARCH WORDS HERE <--- Enter this into google
It works better than the onboard search function many times.
[email protected]
[email protected]
- baja5
Most of us just summons David58 if we can't find something. Seems to work better that Google or any other search engine. Thanks David, and keep up the good work.
- fusername
haha yeap.
- david58
I can't help it you guys are just too lazy to type in a couple words and search.baja5 wrote:Most of us just summons David58 if we can't find something. Seems to work better that Google or any other search engine. Thanks David, and keep up the good work.
- baja5
There is NO doube about this, you are 100% correct.david58 wrote:I can't help it you guys are just too lazy to type in a couple words and search.baja5 wrote:Most of us just summons David58 if we can't find something. Seems to work better that Google or any other search engine. Thanks David, and keep up the good work.
- Lotrat
I just need you to hit my enter key. It's too big for me.
- david58
Let me find my hammer buddy.Lotrat wrote:I just need you to hit my enter key. It's too big for me.
- perrib
Thanks david and Doc
It worked for me. http://www.google.com/sitesearch/
Enter your website's URL and a sample search query - and see Google Site Search in action for your website.
Enter a site URL: Query:
http://www.shoptalkforums.com rocker geometry
It returned 3 pages.
- doc
- Site Admin
This may help until I get the reindexing done. I'm up to about 80,000 posts.
http://www.google.com/cse/home?cx=01563 ... kzexyznqdi
doc
doc
- doc
- Site Admin
I have reindexed about 100,000 posts now. Search should be producing much better results, at least for common queries.
doc
doc
- doc
- Site Admin
We've run into a glitch with the upgrade that will take a little time to fix. Simply put, all the posts have to be "reindexed" so they become searchable under the new system. Unfortunately, since we don't pay for a dedicated server, this is a long and drawn out process. I'm working on it as fast as I am able.
Here's how it may impact you. At 5 minutes before the hour, i start the reindex function. I can only let it run until the hour - just 5 minutes - or it will shut down the board for the next hour. Usually my timing is pretty good and members will not even know it is happening. But there are several variables i can't control and sometimes the board will become unresponsive for the last one or two minutes before the hour. If this occurs and you try to post or search or log on, you will receive a general error message. Bummer!
If you are not logged on, just wait a minute or two and try again. All should be normal. If you are logged on, just click back in your browser and try again in a minute or two. Again, all should be normal. There is seldom a need to relog in. Just wait a minute and go on.
I apologize for this inconvenience. The prize is after a few weeks the search function should work better than ever. This issue could be avoided by changing over to a dedicated server, but the price is 5 times as much as what we pay now and since member contributions now pay for STF, cheaper seems better. The shared server we are on now is doing very well for the boards regular functions. It is just this once in a blue moon things that causes a small convenience. I beg your forbearance. It'll be fixed soon.
Thanks,
doc
Thanks,
doc
- MarioVelotta
The Google searches work awesome. Can you just put that up by the donation button
[email protected]
[email protected]
- doc
- Site Admin
Try the link in my post above. Makes it even easier.
doc
doc
Sigurd
I haven't tried the Google search yet, but an STF search for 'w120 compression' with all terms ignores it because it deems 'compression' too common. Is this still a bug in the search feature?
