Page 1 of 2
Injector Tester.
Posted: Tue Dec 01, 2009 9:08 am
by Dale M.
Any body build their own fuel injector test unit...... Seems it would be pretty simple....
Dale
Re: Injector Tester.
Posted: Tue Dec 01, 2009 9:34 am
by david58
Redline Weber : Injector Tester.
Posted: Tue Dec 01, 2009 9:36 am
by Redline Weber
Yes, this function is "built-in" to the RedlineWeber family of EMS with data logging.
Lance
Re: Redline Weber : Injector Tester.
Posted: Tue Dec 01, 2009 11:33 am
by Dale M.
Redline Weber wrote:Yes, this function is "built-in" to the RedlineWeber family of EMS with data logging.
Lance
Will it work as a "bench test"?
By the way, how come you have time to be here when your site has so many image links that are broken........
Dale
Injector Tester.
Posted: Wed Dec 02, 2009 10:11 am
by Redline Weber
YES.
The RedlineWeber site is NOT my site.
The site is owned by WorldPac, run, operated by WorldPac.
I do appreciate the "advise", they have been notified.
Lance
Posted: Wed Dec 02, 2009 11:10 am
by Dale M.
Redline Weber wrote:YES.
Lance
I'm sorry , I misunderstood you log-on id with the commercial Weber site.... Please ignore my comment....
Dale
Posted: Thu Dec 03, 2009 5:03 am
by warp
I think MS2 also has some sort of injector test mode.
Has anybody tried this?
Posted: Thu Dec 03, 2009 6:53 am
DIYAutotune,Glens Garage etc flog a nice little kit for bench flow testing injectors...
http://www.glensgarage.com/catalog/ject ... p-109.html
They sell it preassembled as well.
Make sure your "bench" is OUTSIDE.
Posted: Thu Dec 03, 2009 8:37 am
by Dale M.
Wow, that pretty much what I had in mind (not quite so exotic though), now I don't have to design something and hurt my brain to figure it all out....
Dale
Posted: Thu Dec 03, 2009 9:03 am
Exotic for ~$50, and you cant catch anything contagious from it , hard to beat
Posted: Sun Dec 27, 2009 5:32 am
by david58
Posted: Sun Dec 27, 2009 10:53 am
by miniman82
WARNING!!!
The above circuit should only be used on high impedance injectors, if you wire a peak-and-hold (low-resistance) injector that way you WILL burn it up. Even with high-z they might get a little warm in operation, so keep an eye on them. For low-z you need some form of current limiter, like an inline resistor. The Megamanual outlines which resistors to use, and where to get them. Reason being, P&H injectors open at full current then drop down to some percentage after only milisecond(s). I promise your fingers don't react that fast, so 'intermittently firing' them that way is asking for trouble.
Posted: Sun Dec 27, 2009 2:17 pm
by raygreenwood
Posted: Sun Dec 27, 2009 2:54 pm
by miniman82
The phrase 'burn it up' needs to be taken literally here, since pressurized flammable liquids will be involved. Would probably be a good idea to use a sealed switch in the design too, to eliminate stay sparks that might cause an ignition.
Posted: Sun Dec 27, 2009 9:19 pm
by Dale M.
I would think a valve in the line as close to the injector as possible would also have better control (amount spilled) of "cleaner".....
Would also like to see these systems inside some sort of containment system (chamber)...
Dale
