Page 1 of 11
Chris/Marc's project
Posted: Sat Aug 28, 2010 5:06 am
by Chris V
Re: Chris/Marc's project
Posted: Sat Aug 28, 2010 8:31 am
by turbobaja
Chris V wrote:
Most people would have a few dumbells or some bricks maybe to stack up to add weight. You've got enought extra cranks and flywheels to do the job
Looks like a really fun project you guys are working on here. What's going to be powering it?
Posted: Sat Aug 28, 2010 12:34 pm
by Chris V
Well, that may be a number of different engines...we've spent so much time thinking about it, I just need to finish it, put something in, and drive it. Probably: a) 1600SP b) stock-valve 1915 or c) big-valve 2-liter so anything from 50-150hp - I'm not picky
It does have a late IRS trans with a GBE mid mount and Type II CV's - so it can take
some abuse if need be.
I also picked up another `69 that I want to do a much, much more subtle resto custom job on...more sleeper. But decided this one needs to be finished first.
Posted: Wed Sep 22, 2010 7:23 am
by Chris V
Posted: Tue Oct 05, 2010 6:22 pm
by Chris V
Posted: Mon Oct 18, 2010 10:24 pm
by Chris V
Have done a bunch more wiring, and finally have the steering column installed...this is gonna make pushing it around a lot easier
Posted: Wed Oct 20, 2010 4:05 pm
by Chris V
I could use a hand on a measurement if someone has the time, I would like to know on a `64-`66 Beetle the measurement from the drip rail on the A-pillar to the leading edge of the turn signal (or to the center of the hole in the fender for the wiring)...Should be in the ballpark of 27-30" to the leading edge of the signal I'm thinking.
Posted: Thu Oct 28, 2010 4:58 pm
by Chris V
Got my 996 storage bin fitted to the dash today, had to some whittling and grinding - still need to make a support, but I'll need to turn the car around in the garage to find the room for that.
So I've been looking for an answer regarding the fresh air knobs...seems that `73+ Super Beetles have lower profile ones and they'd be more pleasing in the unpadded dash, does anyone know if they fit the square plastic pegs just the same as the STD & early Super ones?
Posted: Fri Oct 29, 2010 1:26 am
by Chris V
Made this mount...Two M6 tin screws from the ashtray into it, and then an M8 bolt w/fender washer from the back of the bin.
Also found one short knob (actually found three different lengths) in our collection of knobs:
And re-routed a factory 6mm power wire (heat-shrinked over the entire length of it) so it's not running with the rest of the loom:
Already tempted to take it out and put an 8ga wire in...but it'll probably be just fine the way it is, should be easy enough to do later if I change my mind.
Posted: Fri Nov 05, 2010 9:32 pm
by Chris V
Posted: Sat Nov 06, 2010 4:24 am
by DWP
Nice job,like the paint.
Where did you get the front hinges?
Dwp
Posted: Sat Nov 06, 2010 11:57 am
by Chris V
Actually bought the car painted with the hinges as well years back...I know the bumpers came from Briz - a local company. There's another shop that specializes in this stuff that may have done the hinges - called Billet and Acrylic.
Posted: Tue Feb 01, 2011 8:00 am
by timberwolf177
I love the pic of the ball joints tucked into the rim.. that has always been one of my concerns.. with that being said, what is the rim size and et? And do you have a narrowed beam?
Thanks,
Brad
Posted: Tue Feb 01, 2011 2:56 pm
by Chris V
15x5.5" factory 911/912 chrome rims - dropped spindles, no spacers that I recall...
I couldn't get away with this with Beetle 4-lug 15x5.5 Lemmerz steel wheels because the bell of the wheel was just a bit smaller, had to run some spacers to clear the lower BJ
17x7 ET 55 I think - Dropped spindles and I think about 30mm spacers (I've had several combinations of spacers)
Stock width beam, slightly trimmed the upper shock ears for more tire clearance. I think I get about 2-1/4 turns lock-to-lock.
Posted: Tue Feb 01, 2011 4:45 pm
by doc
Really looking good!
doc
