Is there any new info regarding cylheads for Oxyboxer.
mainly type 1 heads BUT with WBX/OXY boltpattern or undrilled.??
CB or others could make a market here.
Cyl Heads for Oxyboxer
Re: Cyl Heads for Oxyboxer
Thats how I did.
I plugged the org holes, welded them, milled, welded ,milled, welded.......
Then I have built a drilling template and redrilled the holes with wbx bolt pattern.
With undrilled heads it would be way much easier.
The link to my build thread at butalk forum
http://www.bug-talk.de/forum/viewtopic.php?t=26451
- fastback
yes also an option
was hoping to get away with less machinig ...some day.
- fastvwman
I had mine setup for regular vw pattern since I allready had 94 pistons and cyl heads.
Hey Fastback!
Try Rocky Jennings. He supplied me with a pair of undrilled CB CE`s some time ago.
He can also do the required machine work for you, for a "ready to bolt on" option if you want that.
All his work is great!
Or, just order some MS heads from JPM in WBX bolt pattern
- fastback
ey .. cheap'O racing . remember
thought maybe 044 heads 42/37.5 or 40/35 in WBX pattern would be a nice price part that would sell good.
as far as i see the biggest issue is relocating the head studs.
