I got a 1.9 wasser case that one day will be turned into an oxyboxer and was wondering if the 101.6mm cylinders that are available fit in to the case register without machining? Was going to try a 69 x101.6 combo and get new heads from CB without head studs drilled as i read on Cal-look forum that they can be had on special order.
Cheers Damo.
