Engle VZ-25 in WBX / Oxy boxer
Posted: Fri Nov 05, 2010 3:22 pm
by fastback
I have a VZ-25 here that i'm considering to use in my oxyboxer with the appropiate bushings.
then i can use the stock rockers etc.
BUT som say due to the high lift/fast ramps that they are very harsh on the lifter bushings.
the WBX / Oxy case is aluminium and maybe stronger here than stock type 1?
i have som 31mm lifters to go with this cam and will use the dual wbx springs
any thoughts?
Re: Engle VZ-25 in WBX / Oxy boxer
Posted: Sun Nov 07, 2010 5:45 pm
by Stripped66
Run it.
The VZ series cams have been followed with caution by how they wear out the bores in magnesium Type 1 cases. With bronze bushings in the aluminum wasser/oxy case, I don't anticipate you encountering too much trouble.
Posted: Mon Nov 08, 2010 1:35 am
by fastback
thx! i asume it would be lot of horror stories if these lead to total failure most of the time :)
