Venturi, Volute, or plain old Funnel?
Porsche made enough running changes to the 356B engine (introduced in 1960) to redesignate it (616/2 to 616/12) and one of those changes was to add a fan shroud intake volute that really improved air flow.
The 356B models, specifically the Super's, were running hotter and needed the cooling help.
VW did not add this feature to the Type 1 until 1975, for the hot-running FI engines. Awesome Powdercoat
http://www.awesomepowdercoat.com/Venturi_Ring.html
... run by the hardworking Clark Callis offers a copy of the factory device which he calls a venturi ring, and
http://www.mamotorworks.com/acvw-air-co ... -8663.html
... Mid America MotorWorks offers one as well.
The photo above shows the device we ordered from Clark. Excellent fit, and easy to pop-rivet in place.
The device really isn't technically a venturi, but fits the volute description better. In the Porsche Technical Manual, Henry Elfrink calls it a plain old funnel. No matter what you call it, Porsche never made such changes for nothing. The device smooths airflow into the fan housing intake, making the fan work more efficiently.
The result is better cooling.
FJC
