Hit and run
perrib
Hit and run
Post by perrib »
A nieghbors kid side swiped a customers one owner 1988 Jetta that was parked and ran off.
I found some perfect doors (before the hail storm) but of course they were black.
Saturday I stripped the doors to a shell and painted the insides.
I did not get to far today but they are on and I roughed out the front fender.
While not visable the impact cracked the bondo and paint on an old repair to the drivers C pillar.
DannyK
Re: Hit and run
Post by DannyK »
Nice work, I like it when people do things right !
dstar5000
Re: Hit and run
Post by dstar5000 »
I drove to this town and picked up a BMW.....
Pretty bad shape...
After 3 days(and parts from at least 3 more cars) of work(OK, one day waiting for paint to dry)...
This is just a hobby for me....it is satisfying to build something. :)
Don
perrib
Re: Hit and run
Post by perrib »
Don
You making me feel slow and old. This is all I got done today.
Rage Gold bondo my favorite. It does not clog sand paper.
Will be feather edging and shooting primer.
dstar5000
Re: Hit and run
Post by dstar5000 »
Those first couple of pics made my back start to ich, looks like a GREAT backscratcher!
Looking GREAT! You got a lot accomplished!
Don
perrib
Re: Hit and run
Post by perrib »
Not much accomplished today. Since I don't have my heat lamps anymore I'm letting the Marson's ureathane primer surfacer dry 24 hours. Plans are to spot and blend the front fender then install the drivers door.
Evercoat 2 part spot putty. Great stuff. It does not shrink.
Note the old damage to the edge of the fender that was hidden by the wheel opening moulding.
perrib
Re: Hit and run
Post by perrib »
I accomplished a bit more today, most of the block sanding is done. One more coat here and there should do it.
The good thing is I got the color done on the front fender. Now I can mount the drivers front door. The paint is fine but the shadows make it look bad.
perrib
Re: Hit and run
Post by perrib »
It has been cool so to be safe I let the primer dry a couple of days before sanding and repriming.
SEM bumper dye for the trim and bumpers.
Note the day and night difference.
Right side trim plastic trim dyed.
Pinstriped, painted the rocker panels and picked up the trim clips from VW today, Finally it is done and delivered.
dstar5000
Re: Hit and run
Post by dstar5000 »
BEAUTIFUL! I need somebody to spray the color on my bug, you up for it? ;)
I'm not a pro painter, I know that and can live with it since most of the time
I paint cars that will be OK with a "10 footer" paint job.
I painted my bug once, but didn't like the results, so I sanded it all back down
and re-primed everything and am ready to get the color sprayed again.
Heree's the kicker, if it was regular paint, I would be OK, I'd just keep spraying
and then just color-sand it back down to perfection. ;)
I'm using 2006 Ford Mustang Laser Red Met, with pearl in the clear. Problem is
that this is TINTED paint and even after 3 coats, you can still see *through* it
and thusly the shading has to be perfect.
Don't know if *I* want to try my hand again or not, most likely NOT!
I got a pro to look at it, all he has to do is spray the color and clear, and he
quoted me EUR800, about $1200.
PAINT is EXPENSIVE in Europe!
Don
perrib
Re: Hit and run
Post by perrib »
If it is done in a clean down draft paint booth with the correct paint guns that would be worth it. You might check out the trades schools that teach body shop skills. Painting out side or in an old booth requires quite a bit of sanding and buffing. Many paint stores sell a small piece of paper with a black and white checker board that gets taped to the masking paper. It lets you know when paint coverage is enough. All that is moot unless you have a steady hand along with real nice $400 plus paint gun with a perfect spray pattern. Base coats and clears often require changing gun internals to compensate for different viscosities.
Re: Hit and run
I am just a bit late but nice job perrib.
Passatman
Re: Hit and run
Post by Passatman »
Hey Perrib what is this thing sticking from the door.
