Oxyboxer build thread
Steve Arndt
Re: Oxyboxer build thread
Post by Steve Arndt » Tue Nov 13, 2012 9:03 pm
A lot of people run with an external cooler only and no doghouse cooler. Miniman, and Stripped66 for example.
fastback
Post by fastback » Wed Nov 14, 2012 7:14 am
put an sandwich adapter under the stock oil filter and run to an external cooler.
or put the cooler in the return line from the drysump.
andy198712
Post by andy198712 » Wed Nov 14, 2012 3:11 pm
Is it common to use t1 heads on oxy's then?
I'm new to the oxy game.
If this build is anything like your 1835 build it'll be amazing!
grelland
Post by grelland » Wed Nov 14, 2012 6:21 pm
Thanks for your replies, guys.
A plan is forming in my head, but a couple of questions along the way:
1) Is an inline external cooler with no thermostat be a good idea? I am concerned about not reaching optimal oil temp if all the oil is cooled always. (I know Jørn (fastback) propsed that then I am driving too slowly...)
2) Not having mocked up the entire engine incl excaust, will there be space issues by using a sandwich thermostat under the original filter?
Thanks again
grelland
Post by grelland » Wed Nov 14, 2012 6:24 pm
andy198712 wrote:Is it common to use t1 heads on oxy's then?
Thanks for the kind words.
Yes, T1 heads is "common" on oxys. However the stud pattern differs somewhat from wbx, so there is basically three options:
1- Reposition studs in the case
2- Buy un-drilled T1 heads, and machine stud holes in a wbx pattern
3- modify T1 heads to "fit" wbx pattern.
At the moment I am leaning towards no 3, but I will need to get my new heads delivered, so I can have a closer look.
grelland
Post by grelland » Wed Nov 14, 2012 6:28 pm
On the note of stud pattern:
I trial mounted the barrels the other day, and with using 8mm studs, this is the clearance with a std wbx pattern:
Based on this, I will attempt to slightly enlargen the stud holes in the heads, and see if I can get away with not relocating the studs in the case
grelland
Post by grelland » Sun Nov 18, 2012 4:59 pm
I had a short visit in the garage today, and decided to measure the rod bearing clearance, and using platigage, the measurements came out like this:
mm
1 0.08
2 0.05
3 0.08
4 0.10
I see the Haynes manual states 0.02 - 0.15mm so I am well within that, but I have also seen people refer to 0.001 to 0.002", which gives 0.025 to 0.050mm, and then I am outside.
Anyone that would be concerned with these numbers?
andy198712
Post by andy198712 » Mon Nov 19, 2012 4:07 pm
did you fit inserts and then the 8mm studs? also how did you over come the cylinder OD to case ID issue?
quite tempted my self!
grelland
Post by grelland » Mon Nov 19, 2012 5:14 pm
For this mock-up I have used the stock studs, but my plan is to use inserts and 8mm studs with M8 threads.
The cylinder OD to case ID issue will be solved by machining down the barrels to the right OD. They are too long as they are, so I will have them machined, but not the "stock" T1 OD, but one that just fits inside the case. I just need to mock up the engine first to measure the deck height in order to determine how much I need to shorten them.
Go ahead, this is fun :)
andy198712
Post by andy198712 » Tue Nov 20, 2012 6:12 pm
cool stuff!
just need to find a case!
Stripped66
Post by Stripped66 » Thu Nov 22, 2012 4:27 pm
grelland wrote: I see some people add an adapter and a bracket so that they can use a doghouse cooler. With the planned external cooler and the external oil tank, will need the doghouse cooler, or can I get away with the external one only?
This decision is entirely up to you. I ran Rocky Jennings adapter on my oxyboxer when I was still running the stock-style cooling shroud:
http://images.thesamba.com/vw/gallery/pix/378317.jpg
The stock oil cooler is an excellent design, and Rocky's adapter keeps the oil plumbing short and simple.
Since changing to a 911-style shroud, I've used only an external cooler. I previously used a 96-plate Mesa style cooler, and only recently switched to a smaller Setrab cooler. The construction of the Setrab cooler is superior and more efficient than the Mesa cooler.
Stripped66
Post by Stripped66 » Thu Nov 22, 2012 4:31 pm
grelland wrote:I had a short visit in the garage today, and decided to measure the rod bearing clearance, and using platigage, the measurements came out like this:
mm
1 0.08
2 0.05
3 0.08
4 0.10
I would try to borrow a bore micrometer to check your bearing clearances. Set a standard micrometer to the diameter of each journal, zero the bore micrometer to the standard micrometer, then measure the inside diameter of the bearing while torqued within the rod to determine the clearance. I do not trust Plastigage measurements one bit.
grelland
Post by grelland » Thu Nov 22, 2012 4:41 pm
I will be using a dry sump, so the oil will come out of the case anyways, so I guess I will end up using an external cooler. Thank you for sharing your experience.
grelland
Post by grelland » Fri Nov 30, 2012 5:18 pm
Not much progress here. Work is eating all my garage time...
But I got some goodies in the mail, including a key element for next year's upgrade:
During the weekend, I plan on checking the main bearing clearances before I send the crank and flywheel out for balancing.
The heads are due in a couple of weeks also, so then I can finally start some serious work on this engine :)
grelland
Post by grelland » Mon Dec 03, 2012 5:36 pm
While waiting for some parts, I am planning a dry sump tank in the space behind the rear wheel in the Ghia. But does anyone know what sort of oil capacity I will need? I see CB sell tanks which are 12 qts, but is'nt that quite big?
Any inputs?
