Killer Flop-Stop Decamber Trick
The humble "flop stop" is a much-misunderstood little piece of ingenuity. It's overlooked because its so simple and cheap (usually under $10 when you can find them), but it can be extremely effective and help you tame your swing axles by being a fine tuning device.
The purpose of the "flop stop" is to limit downward movement of the swing axle by raising the spring plate stop.
All you have to do is use two spacers in the flop-stop rather than one. Each Flop-Stop clamp comes standard with one spacer that is 3mm thick.
Installing a Flop-Stop is easy. Jack up one side of your car, leaving the other rear wheel on the ground, handbrake set, and as you raise the car note that the spring plate will lift off its rest.
Don't try this with the other side of the car already up on a jack stand. You need the leverage you'll create by having the other side of the car as low as possible to make the spring plate rise.
Jack up the car enough to slip a Flop-Stop (with one spacer) inside onto the bottom of the spring plate , and slid it forward until it slips into an indentation that looks like it was made for it.
Put a drop of thread lock on the set screws, tighten them, and that's it.
In these photos, we've used two standard 3mm spacers. With two spacers installed, you'll note you can no longer easily jack the car up enough to lift the spring plate high enough to just slip on the Flop-Stop. With two spacers installed, I had to use my spring plate tool to lift the spring plate enough to tap on the Flop-Stop.
Once the double-spacer Flop-Stop was in place and I lowered the spring plate again, I found what I expected to be true, but better. 6mm of spacing gives you an almost level axle attitude. Obviously, thinner spacers could be used to tune your ride height.
I was just expecting less positive camber and axle droop. "Nearly level" was almost too good to be true. This simple mod puts the Flop-Stop into the camber compensator class of usefulness, but at less cost, time and trouble.
FJC
