Removing paint with heat
I have a rail so we are not talking body skin. What do you think about using heat/torch to remove paint? Just enough to cook the paint not turn the metal red.
Re: Removing paint with heat
The off-gassing with paint removers is bad enough, heating the paint is really bad to inhale.
Steve Arndt
Post by Steve Arndt »
Try some paint stripper from the auto body store is my advise. Also you can apply the stripper then cover with saran wrap to make it more effective.
Ol'fogasaurus wrote:The off-gassing with paint removers is bad enough, heating the paint is really bad to inhale.
So wearing a full face respirator ( not dust mask) would take care of the vapors. would the heat be bad for the metal?
The resperator couldn't hurt. Either of the two ways talked about are messy.
DWP
Post by DWP »
The problem I see is getting hot enough to burn the paint away. I know areas near where I am welding get hot enought to peel,lift,burn the paint. I still have to go back with a wire wheel an clean it. Try a small area first to see how good it works. You might find that a wire wheel will work just as good and leave a frame ready to paint.
DWP
As i tell my son, waste money on cars not Girls.
You can always sell the Car.
I often use a wire wheel on a 4 1/2 " grinder.
DWP wrote:The problem I see is getting hot enough to burn the paint away. I know areas near where I am welding get hot enought to peel,lift,burn the paint. I still have to go back with a wire wheel an clean it. Try a small area first to see how good it works. You might find that a wire wheel will work just as good and leave a frame ready to paint.
DWP
Ol'fogasaurus wrote:I often use a wire wheel on a 4 1/2 " grinder.
That is the route I am taking. Can also get some of the rust spots while I am at it. 8)
Bought a knot wheel at Ace for 18 bucks, bought a Dewalt knot wheel at Lowes for 14 bucks, the dewalt wheel does a better job and is lasting longer. The fire thing, well even if you use that you still have to knock off the residue so nothing gained with that. Took 2 Ace and 1 dewalt wheel to strip the rail.
