Coils coils coils
- Turbo_Manx_Maniac
Coils coils coils
For my new car I'm building a new MSII based on a 3.0 board, coupled with Marios crank trigger. I will be distributorless for the first time so I'm looking at wasted spark coil options.
I'm shying away from an EDIS pack for several reasons, I want spark cut for rev limiting, and I'm not sure I trust an EDIS setup to reliably light off a VW under 20 psi of boost. Then there are the funky spark plug wires
I like the thought of a single 4 coil pack (like EDIS) rather than mounting 4 coils remotely due to space, simplicity and cost.
So am I over thinking this, should I just run an EDIS pack?
What are your thoughts on logic level trigger vs having MS fire a coil?
Looking for ideas to make this simple and effective.
I accidentally Googled my Twitter. (And I liked it)
Re: Coils coils coils
If you're worried about it, run the Accel EDIS coil. Supposed to be stronger, though the regular one is pretty potent.
- supaninja
EDIS was the bee's knee about 5 years ago, things have changed and direct fire is where it's at. I'm just running gixxer coil packs (the friggin long ones too, boooo me), and I friggin love the ign setup. I had a little drama with resets on the non-resistor plugs but resistor plugs solved that, since then drama-free. I'm only at 2000 miles on this motor/ms setup, but the ignition system is the best part of it.
viewtopic.php?f=14&t=140387
- MarioVelotta
[email protected]
[email protected]
- Eaallred
I'm running these Accel #14033 ignition coils in wasted spark form until I get around to doing a cam sensor to go sequential:
They pack a pretty mean punch. Me and Chip bought a V8 set and split them.
- Turbo_Manx_Maniac
This is where I'm leaning, that and a couple BIP373's should do it. I sent a message to Matt at DIY to see what kind of performance that coil pack produces. Want to stay compact, no COP this time around.
- MarioVelotta
These are compact but I'm not sure if they will light off that much boost.
[email protected]
[email protected]
- Turbo_Manx_Maniac
Matt from DIY sent me an email response saying the 4 pack will do the job so I ordered it. I'll add the BIPs when I build up the MS2. Going to make one all encompassing harness so I can sell the motor later as a turn key setup. Will also help me remove it from the car when I swap to a water pumper.
Too hard to sell a FI turbo motor without it being a bolt in thing for people, too much fear of computers and wires, but they love it when it's turn key.
- MarioVelotta
I'm eager to see how they perform. I would love to witch to new coil packs instead of used EDIS packs in my kits.
[email protected]
[email protected]
You should have kept those LS2 coils
They really are easy to work with and the ignition noise is ~zero at the MS.
I Do appreciate the deal tho!
- Turbo_Manx_Maniac
Well, to be honest I probably would have still wanted to stick with one pack to keep the harness cleaner when I sell the engine, no interest in going sequential. I'm going to add a heavy duty 3 pin connector to my MS box for the ignition, this way I will have a separate ignition and fuel harness to simplify things and hopefully better shield noise.Piledriver wrote:You should have kept those LS2 coils
One of my main concerns with this coil pack is I would have liked to be logic level trigger for the reason you made. I'm sure it will all work out fine in the end....
- Turbo_Manx_Maniac
We'll know soon enough, should have it all together and prototyped in less than a few weeks. The coil pack/BIP373 is suprisingly cheap, wonder if it's the same coil SDS uses?MarioVelotta wrote:I'm eager to see how they perform. I would love to witch to new coil packs instead of used EDIS packs in my kits.
i'm planning on using the one off the mk4/5/6 vw golfs, they do a the 1.8 turbo but unsure of how they boost and rev limit...
MarioVelotta wrote:What about this guy?
Back to OEM coils? I thought the point was to find something stronger? Might as well stick with EDIS...
- MarioVelotta
Talking to me or TMM?
[email protected]
[email protected]
