vw 1978 bus rear end
carlost2
Post by carlost2 »
who can tell me the gear ratio on a 1978 vw bus?
Re: vw 1978 bus
Post by Marc »
I can't say with certainty. Even if it still has the same trans it left the factory with, there are still 2 possibilities. Best thing to do would be to count turns on it. The R&P ratio choices are different for a Bus trans than for a Bug, but it's a fairly safe bet that 2nd is 2.06 and 3rd is 1.26...the procedure's the same as discussed here: http://www.shoptalkforums.com/viewtopic.php?t=80760
Ratios:
http://web.archive.org/web/200905031128 ... /gears.htm
Re: vw 1978 bus rear end
Post by Marc »
Never mind, apparently it's an automatic. Someone else'll probably respond before I dig up that answer.
http://www.shoptalkforums.com/viewtopic ... 0&t=137265
carlost2
Post by carlost2 »
Thanks marc,
Post by Marc »
Found something. Let's abandon this thread (the moderator can either lock or delete it) and use the other one if anyone has anything to add:
carlost2
Post by carlost2 »
Thanks marc,
