This is a brand NEW ceramic coated Tri-mill T-4 header for a Baja or buggy. It's complete with the T-4 "J" pipes (also ceramic coated) and comes with a lightly used stainless steel clamp-on Supertrap muffler/spark arrester with 3 3/4" 6 bolt discs. This is a really high quality header that has super thick flanges so you don't have to worry about distortion and leaks. Uses standard T-1 muffler gaskets at the "J" pipe flanges so each tube has 2 bolts holding it on rather than the standard 3 bolts for both pipes like most T-4 exhausts. This also enables you to run re-usable copper gaskets.
Price is $650 shipped to the lower continental 48 states.
See my other ad for a 911 fan shroud kit.
