I have had a fair bit of help putting my system together. It finally runs, but idles at about 1400 rpm. I am running MS2 V3 & have done the mods to the board to run a pwm idle valve, but just can't get it to work.
I have tried loads of settings to get the idle valve to work, so am looking for either a settings solution or a physical one.
Is anyone running the standard valve or have they been blanked or replaced with something else.
If I put my thumb over the valve completely the engine will stall.
If I earth the valve it will rev to 2,000 rpm.
Engine is a 2017cc with a T2 turbo running all VW Mexibug efi with Audi TT injectors..
Everything is built mild to push a bus around.
I have heard of people porting the TB, but not sure if that's just for performance.
I really want to get this sorted before I fit it in the bus.
