Wiring Grommets
Max Welton
Wiring Grommets
Post by Max Welton »
I am rewiring my 67 type-1 KG and don't have the stock harness for reference.
What have people used for grommets where the wires pass through the headlight buckets and bodywork?
Max
FJCamper
Re: Wiring Grommets
Post by FJCamper »
Hi Max,
If you're going for functional, you can improvise grommets from rubber hose split to fit and glued or hose-clamped in place, to grommet assortments from the auto parts store.
If you need concors, you've have to go to
http://www.karmannghia.com/page.asp?pageid=34
http://air-cooled-vw-parts-search.mamot ... &w=grommet
... they are out there.
Good luck,
FJC
sideshow
Re: Wiring Grommets
Post by sideshow »
Some catalogs list this as a beetle part, some list it as ghia also. I don't know who to believe but this does fit the idea;
http://shop.westcoastmetric.com/viewPro ... ID=111-185
Max Welton
Re: Wiring Grommets
Thanks guys!
